By Peter Shupe
#201862
I've rendered Max 9 and new plugin for over 20 hrs??
By Onslaught
#206694
I'm having a similar problem. I set up the time for 480 min (8 hr) render, once I hit the render button the time changes...one time it's 4hrs sometimes 3hrs?
if somebody knows how to fix this I would really appreciate the help.
thanks
By homegrown
#206724
Is it reaching your desired sampling level before your desired time and then quitting?
By Renante Solivar
#212532
it's not reaching my design time. help please.
By jomaga
#212550
Maxwell stops when:
-Reach the time limit
OR
-Reach the desired sampling level
If you set your time limit to 1000000h and your desired SL as 1, Maxwell will render until SL1 time, probably less than 1minute and stop
