- Tue Dec 12, 2006 12:29 pm
#200421
Hi guys,
When I set the USE MULTILIGHT option i can see the toggle enabled in Maxwell Render but it doesn't work even if i start the rendering from the command line with the -ml option.
The strange thing is that if i load the scene in Maxwell Studio it renders correctly with multilight working and it creates an image with low noise much much quicker than if i start the render from my application.
Also if i save the scene from Studio, it's always a little bigger than the scene saved from my application.
Also my resulting MXI is always ~35 MB even with multilight enabled, while fron studio it's much bigger with the same option active.
If someone can give me some advice....
Thank you in advance.
- By Mark Bell
