#200252
Hello
I have a problem and i wonder to know if anybody knows how to help me, i think maybe is easy but i still can get a solution for this.
When we import one object into C4D and that object has many materials, but is only one object, not each object part to each material. How can we separate in different object to each one has his own material.
Because i can assign maxwell materials in multiple materials object.
thanks
best regards
goncalo
By mashium123
#200257
Hi giacob.
I'm not sure that I understood your question.
http://www.studio-fabian.de/
This is the link to Fabian Rosenkranz' s site. He writes great stuff for c4d.
When you follow: ->Downloads->version 8.x, then you'll see the Plug-In "SplitToObjects". This plug makes separate objects out of your selections.
With the prior c4d-plug we had to use, I couldn't live without it...
Perhaps this is helpful.
Mesut.
By Boris Ulzibat
#200273
Switch on "Polygons" mode.
Select the saved selection you need.
Press the "select polygons" button.
Right click anywhere in the viewport and select "split" function.
This will create a separate object containing only selected polygons, the parent object however will remain unmodified, so it is a copy of selection.
By Boris Ulzibat
#200285
goncalo wrote:IT WORKED :!: :!: :!: :!: :!: :!:
MANY THANKS :P :P :P :P :P :P
king regards
goncalo
No problem :D :D :D
By Tyrone Marshall
#200306
Boris Ulzibat wrote:Switch on "Polygons" mode.
In R10, you can just double-click on the selection tag and polygons will be automatically selected! :D
By Boris Ulzibat
#200319
Thanks!
Didn't figure out all the cool features of R10 yet :D :D
By spekoun
#200334
But there is no need to split multimaterial objects any more i you use last plugin. Just add Maxwell tag and drag polygon selection into according slot. Work fine to me....
