#200044
Hello all,
With the release of the new 3ds max plugin (07-Dec-2006), i came across of a nice and pretty fast
solution for showing caustics through glass/water.
Next i'll describe how i made this image (just SL 11 and some nice water caustics):
This is how i did:
1- for the water i modeled it, then applied a noise modifier.(lets call it water01)
2- Next i applied a water material
3- Then i duplicated the water mesh (lets call it water02)
4- Unchecked 'visible to camera' option (object properties) for the water01 mesh
5- Then i applied an AGS material for the water02 mesh
Thats all... Hope you guys enjoy it.
(Maybe in the future Maxwell Render wil do this automatically for us...
It could internally do this as i described above)
Best regards,
Nuno
By Fernando Tella
#200072
Great tip! Making water01 invisible to camera makes it still render the caustics produced by it and see through it at the same time.
It's a pity AGS does not produce the fresnel effect of water unless it has a refractive layer which will hide the caustics, right?
By Nuno Faria
#200074
That looks wonderful. Very nice scene
thanks :wink:
yes....thats the 'trick' behind all this
i guess you are right... but in situations like clean/crystal pool water, that isnt to much of a problem, imo. :D
By juan
#200082
Great tip Nuno!
Juan
By DrMerman
#200084
Nicely done mate :)
Superbe tip !! :D :wink:
Very inventive! I think it only doesn't have total internal reflections but caustics and surface reflection.
By Nuno Faria
#200169
of course, this might doesnt work for every situation, but i think it works good enough for the above example.
glad you guys liked it :wink:
By abgrafx3d
#200841
Very nice tip! Thanks.
By jdp
#200842
excellent tip. thanks a lot. :P
By misterasset
#212700
Has anybody else had problems with their caustics looking pixelated? I'm using planes that are 200x200 faces and my caustics look extremely pixelated. Any help?
By Nuno Faria
#212821
misterasset wrote:Has anybody else had problems with their caustics looking pixelated? I'm using planes that are 200x200 faces and my caustics look extremely pixelated. Any help?
try to use "subdivide" modifier with a size of 10cm (0.1m) and then "noise" modifier... if this isnt enough, use "mesh smooth" modifier.
i never run into this kind of issue. hope this help!
nuno
