- Thu Apr 21, 2005 2:04 pm
#18016
After some of the crashes related to material changes with the Maxwell shader some objects dissapear from the Maxwell renderer (not always the objects where i changed the shader before the crash).
Removing the Maxwell shader and reattaching them doesn't help, deleting the object from the scene and later adding it again doesn't help too. Strange enough even if i rename the object filename before adding it again it is unvisible in the rendering.
- By Edward Leibnitz
