#199385
I watched Mike's video, it seem that exporting animation should be simple as using export -> maxwell scene -> check camera & animation.
However, when I hit export, maya gave me
Error: Cannot export Maxwell scene into file 'C:/Documents and .../test.mxs':
Error: Could not save file.
plenty of hd space, no permission setting.
I'm on Windows XP Pro Japanese version <- possible the cause of error???
Any advice?
Thanks
By daimon
#199448
Try setting your project on another location, c:\temp just for test
By beau_cg
#199468
Yes, I can render within maya, single frame and animation(batch render).
I also tried with simple scene, ie. couple of spheres and a plane.
Also tried to save a mxs on a non-space directory, ie. c:
All gave me the same error.
When I tried to set a directory for Maxwell Scene in the project setting,
I got, Error: Object not found: np_FileLocationMaxwell Scene
Edited: If I export a single frame, uncheck the animation, it exported ok, but with animation checked..error
By beau_cg
#199960
no one has this problem??
By Neil Evans
#199963
I have, I found that if you check the export static fly by check box in the render dialog it works. It is wierd as the first time exported it worked fine, then the second time I had to check this box..
Hope this helps.
By beau_cg
#200211
Still didn't work, gaving the same error. :cry:
By Neil Evans
#200213
One other thing I found last night, have you change the image/animation ext. to something other than single frame? This caused an error for me...
By beau_cg
#200228
Actually, when it was set to single frame, it exported fine. But when I changed to animation format (tried them all name.#.ext, name_#.ext, etc)
I got the error...
By Neil Evans
#200229
Wierd one....got me stumped them, sorry!
