Miles wrote:I didn't know that. I think they're making it difficult for a whole segment of the market, if that is the case. I'm not sure I understand the difference between using Parasolid in the SolidWorks plug-in and importing Step into Studio. Or can they use the display mesh in SolidWorks?
PE and SW are not my bag so I don't really know
Miles wrote:Perhaps the problem with AutoCAD is that Megalodesk went their own way since ACIS V7, I think. We're now on ACIS 16....
I use Microstation which is fully AC2007 compliant through the use of the OpenDWG libraries so if NL wanted to it could import DWG no problem.
Though, Automegalodesk has definitley pulled some kind of trick with AC2007 file format because even though AC opnes the DWGs exported from MS with no problem and MAX does as well, the File Link utility in MAX does not work properly with DWGs exported from MS but is fine with ones from AC....
Miles wrote:Thanks, I'm interested. My present workflow is pretty good, though: Step import into Rhino (evaluation version) and then use the Rhinoll plug-in to export to mxs. Part names are retained etc.
Will see what I can find out. The guy that I remember telling me he had figured it out is still on hols. I think he found a way to go out to OBJ that was coming into Studio fine, but I don't know whether parts were retained or not.
