- Mon Nov 06, 2006 10:10 am
#193591
Had the same problem here, i had to update the materials, seems to work fine now! I had this issue when the scene contained some custom MXMs with Windows paths (i work on a Mac and the scene was set up on Win machine). As soon as i corrected all the paths the render started fine.
BUT, i also deleted and removed from trash both the old plugin files from C4D folder and from my downloads folder too.
Don't know which was the reason - but now it works.
And one more thing, check that mxm and mxs files are correctly associated with MXED and MXCL apps by double clicking on them!
When i downloaded the latest UB version of Maxwell and installed it, the connection was somehow lost. This is another possible reason for it.
Albert Kiefer wrote:I dowloaded the latest plugin for Cinemaxwel and placed it in its usual place in the root Cinema folder under plugins and in a folder named Maxwell.
When I try to access the plugin I see that it's called version 1.0.
When I set the options (I cqan no longer choose a camera...) and press either render or write mxs file I get messages like:
"Maxwell constructor"
"Maxwell cannot be initialised. Check installation rules"
"Maxwell Not initialised"
Now I have already checked if Maxwell is actually OK to run and it is... It starts up, can read and render MXS files and also Maxwell Studio talks fine to Maxwell Render. But from Cinema I can not render or write files to the Maxwell renderer...
Any hints or tips to get it working again?
Thanks in advance.
Albert
- By Andreas Hopf
