By cali3d
#191681
Hi all..
I just bought MW and I have two iMacs on a normal local network. How can I make those two computers collaborate on rendering a single image ?
the documentation for the network rendering is quite wierd for a normal user so any help / pointers are much appreciated..
Kindly
Carsten Lind
Denmark
By deadalvs
#191749
hey there !
welcome to our friendly forum where anyone gets help...
steps... just follow them.
first, for the faster machine that also acts as the manager over the slaves (called servers.)
1)
go to:
applications/maxwell
right-click the maxwell app icon and select: show content.
a new window opens and You'll see a folder «Contents». in this folder there's the folder MacOs. In this folder MacOS, there's finally the file called «mxcl».
2) open the terminal (a new shell window)
3) drag-and-drop the file mxcl into the shell window.
the path should appear like this:
/Applications/Maxwell/maxwell.app/Contents/MacOS/mxcl
4) enter just after this line the following:
-manager
hit enter.
(type «minus manager»)
note: this is a flag for the command You give when You hit enter. this starts mxcl in the manager mode.
5) in the terminal, create a new shell window (apple-n), don't close the other window !
6)
same drag-and-drop. then type «-server -p:low»
hit enter.
(minus server space minus priority low)
7) You'll see a new connection on the manager from the ip address this computer has. it found itself, yay!
on the slower computer, the slave:
8), EIGHT) this smiley sucks...
open the terminal, as before, drag-and-drop the mxcl file into it and write «-server -p:low».
hit enter.
9) a new connection should be added to the manager on the first machine, from the ip of the slave.
ok. we have now one manager and two servers running.
now, we want to add a job.
10) same again, new shell window on the faster mac.
11) after the mxcl-line-drag-and-drop write «-d»
this starts the GUI, the maxwell render interface.
12) bottom: go to the network tab.
13) hit options. enter the ip address of the machine, the manager is running on. (probably the same computer again, the faster one) hit enter.
You'll see two green ip addresses under render farm that have the state «connected»
14) on the top of the screen under the menu «file» choose open scene and import the desired scene.mxs
15) check all settings (render options) and SET THE TEXTURE PATH to a directory with all the textures that can be accessed BY ALL the servers in the network !!! otherwise not all servers can find the textures...
16) under the network tab: hit add job.
17) click cooperative and hit ok.
done.
tips:
- specify all the texture paths correctly to ONE place on the network. if a material searches for a texture on /macHD_Cindy's_Computer/stuff/tex.jpg, the rest of the servers won't find the texture because the texture is stored locally on one computer. so the texture must be saved and linked as /networkdrive/textures_for_all_visible/texture.jpg
- choose output paths in the same manner, so that all servers can output their individual files to a path they can find. else You'll get errors like «could not write file»...
all clear ??
just ask again if You got any questions...
greets !
deadalvs
By cali3d
#191765
Thanks alot for your reply and for the explanation .. I will let you know how it goes.
One thing that comes to my mind is, if the scene is on Mac1 and I tell it to render that, will the manager "copy" the scene to Mac2 automatically ? - or will the same rules apply as for textures (having a network drive that both mac's has access to where I put the scene files?).
Thanks in advance..
//Carsten Lind
By deadalvs
#191791
ah, good question. i have not a clear idea about this yet, because i just always ran standard tests with a the nloffice.mxs scene which is on all slaves in the same location, of course locally, but when it's on every server, they all can find it too.
but i remember too that i generated three folders on my network drive:
- textures
- mxi output
- scenes
i must have thought this through once... hmm.
answer: yes, You have to put it also on the network drive, accessible to all servers.
good luck !!
deadalvs
