By seco7
#188715
I use C4D and MY opinion, others may disagree, is that it doesn't work at all IN C4D. This leaves only studio and even the plugin exporter doesn't work very well. Very sad situation indeed.
By kizo
#188753
i have to disagree with seco7. I use it on a daily basis in arch.viz.production
and only with cinemaxwell plug...unfortunately Im stuck with v1.0 becouse in v1.1 the workflow is ruined, so i wait for a new release
its true that the cinema plug is very limited but for standard arh.viz. it does the job very well
By Maxer
#188803
I think the Max plugin has had the most development over all of the others, there are still problems with it but once you learn what the limits are it's possible to successfully work without to much trouble.
By Maxer
#188812
Studio isn't a plugin it's a stand alone rendering application that can only be used for rendering, it has no modeling or animation capabilities and is really only used to edit materials and set up lights and cameras.
