By Brett Morgan
#16921
Hi gang, came across a wierd error mesage after about 2 hours of voxelisation Aaaahhhh :D
here's the console:
bert@darkstar:~$ mxcl -mxs:/home/bert/skyTest.mxs -d -th:4 -res:1800x1500 -o:/ho me/bert/turbines.jpg
MAXWELL RENDER (M~R) version 1_1_33_0001_alpha_
MAXWELL Console Application version 1_0_1_0001_alpha
(C) 2004 Next Limit Technologies
>> Num processors: 4
Reading MXS File: /home/bert/skyTest.mxs
MXS file read successfully
>> Checking Data...
>> Preprocessing Data...
>> Loading Bitmaps...
== Render settings ==
resolution: 1800 x 1500
maximum desired time: 166h 39m 0s
threads: 4
quality: normal
target sampling level: 25
>> Starting Render
>> Start Voxelization...
Voxelization progress: 100%68%
>> End Voxelization...
Stop Render Confirmation( ESC again or 'Y' )
Render NOT stopped
[0h 11m 47s] of [166h 39m 0s] , current sampling level : 0 X Error: BadValue (in teger parameter out of range for operation) 2
Major opcode: 151
Minor opcode: 4
Resource id: 0xa1797
[0h 12m 52s] of [166h 39m 0s] , current sampling level : 0
[0h 13m 11s] of [166h 39m 0s] , current sampling level : 1 Killed
bert@darkstar:~$
I have no idea what I did wrong, maybe a scene file error?
Cheers
Brett
By Brett Morgan
#17315
OK got another error message, different scene:
>> Num processors: 4
Reading MXS File: /home/bert/turbine.mxs
>> Checking Data...
>> Loading Bitmaps...
resolution: 800 x 600
threads: 4
quality: normal
>> Starting Render
>> End Voxelization...
[1193046h 19m 46s] of [166h 39m 0s] , current sampling level : 0 *** glibc detec ted *** double free or corruption (!prev): 0x08255048 ***
Aborted
bert@darkstar:~$ X Error: BadIDChoice (invalid resource ID chosen for this conne ction) 14
Major opcode: 1
Minor opcode: 0
Resource id: 0x2010b
bert@darkstar:~$
is this maybe bad memory?
Brett
