#188210
I did a quick animation recently, and found that the memory leak problem has not gone away as had been earlier reported. Hopefully NL has fixed this in the upcoming updates for the plugins they have been working on.
I've also discovered that you cannot use the constrained path for the Maxwell camera - you get all kinds of wierd results. However, if you animate a dummy object to your path, and parent the camera to the dummy, it will work ok.
By Maxer
#188333
Yes the Max plugin really sucks with regard to animations; you’re also unable to use the auto exposure feature. I haven't had any problems with the constrain to path feature though, I've used it for at least 10 animations without any problems.
