#187528
Code: Select all
http://www.indigorenderer.com/
:!: "Monte-Carlo path tracing or Monte-Carlo Metropolis Light Transfer for unbiased light transfer." :!:
As I am not a CG expert I just show you this, I would like to read your comments.
By the way, it's FREE
Features list...
Experimental support for Bidirectional path tracing and MLT on top of bidirectional path tracing
Materials:
Lambertian diffuse. Can be textured.
Specular - perfect specular reflection and transmission. Obeys Fresnel law for dielectrics. Total internal reflection and refraction is handled accurately. Dispersion and absorption are supported.
Phong - Physically based glossy reflection using phong lobe. Can use a diffuse substrate as well. Can use diffuse texture for substrate and specular texture to modulate specular reflection.
Bump mapping
Geometry:
Sphere and plane primitives.
Meshes can be loaded from .3ds (3D Studio Max) models or from xml scene.
Emitters:
Rectangle Area light emitter
Physically based spectral and sunlight model.
Uniform environment light.
Mesh emitters.
Emission spectra can be piecewise constant, RGB curves, or blackbody spectra.
HDR environment maps using OpenEXR image format or .float floating point images.
Scene is specified in an XML file.
Spectral rendering: light is modelled at the wavelength level, allowing for more accurate reflection and transmission models.
Can specify lens/aperture radius and focal length for depth of field.
White balance setting for virtual camera.
Reinhard tone mapping or linear tone mapping.
Outputs to PNG and optionally tonemapped and untonemapped EXR.
Progressive rendering... watch as the image becomes less and less noisy.
Per-object and scene-wide kd-tree spatial partitioning for fast ray tracing.
Distributed network rendering using slaves/master design.
Indigo has exporters available for the following 3D apps:
3dsMax exporter for Indigo v0.4 by U3Dreal (version RC O.43).
3dsMax 5 - 8 Indigo exporter for Indigo v0.4 by Johan Thorngren.
Cinema4D version 0.5 exporter for Indigo v0.4 by BlackLizard.
Blender 2.40+ Indigo exporter
Maya exporter
Rhino exporter
By jdp
#187557
jtb, it has been discussed extensively on this forum yet, particularly before the rc release. I am pretty sure a lot of people knows about it.
as a side note you have to know that the mlt or sort of progressive path tracing algorithms are in development for a lot of renderer right now, including open source (eg.: yafray).
By jdp
#187561
anyway, I forgot to say thanks... :P
By mtripoli
#187562
it looks nice... but IMO, not as nice as MR...
and then there's the "old" liquid in a glass" problem... :wink:
http://www.indigorenderer.com/gallery/m ... ewsIndex=1
By rivoli
#187570
lol, yes, but none of them is as cute as the cinema one. it even has legs.
By rivoli
#187572
lol. yes, those legs got me confused, I totally forgot about sss. or maybe they just thought: "sss? who gives a shit? we've got legs, haven't we."
By aitraaz
#187574
I've heard that form-z is about to release one with breasts, lots of competition going on out there...
By rivoli
#187575
those guys are so ahead of time, thomas has to come up with something you know.
By Miles
#187576
rivoli wrote:those guys are so ahead of time, thomas has to come up with something you know.
:shock:
By aitraaz
#187585
lol, cutting edge as usual, we're used to it by now... :)
By rivoli
#187588
yeah, I think whiskey told us a couple of times :D
Indigo vs Maxwell.
Indigo:-
Maxwell:-
By JTB
#187633
1. The reason I posted this from the begining, was to show you that Indigo was described as an UNBIASED renderer. I thought Maxwell was the only one.
2. To Tim Ellis : Thanks for test you did, what is your opinion? What about rendering times? I like both of them, Indigo's image looks a little better because it is clear.
