- Tue Sep 12, 2006 12:05 pm
#184328
thought I'd join the fray, so here goes;
I've called this project 'The Box' because I don't know the name of the building and it's sorta box shaped!
I'm doing this a little retrospectively, as I've already started but I'll update this thread as I go...
NB: updates will be added on to the end of this first post.
07/09/06 - Weather was great, blazing sun and clear air so I went into Nottingham and took some reference photo to hone my exterior modelling skills. Picked this one to start with, I've got another one in mind but that's for later...
Resolution = 2048x3072 taken with a Canon EOS 300D with Canon EFS 18-55mm lens at 18mm; 1/200sec, F/8, ISO 100 - I'm planning to render the final at the same res if my PC will take it!
09/09/06 - Spent a lot of time counting bricks! I actually modelled this in XSI using 1 unit = 1 brick height (3 units = 1 brick length) which made modelling really easy and as I didn't have any measurements this seemed a good idea to get the size right. Then I converted to metres at the end.
First thing to do was to camera match. I used an old application called Icarus (I think it was a research project) which is brilliant. All you do is pick an origin point (cyan) then give two parallel lines in one axis (x=red) and two parallel lines in another axis (z=blue). It then very quickly works out the camera location and interest location. The only other data it needs is the lens length (18mm) and the CCD size (14.8x22.2mm). It's absolutely brilliant, very simple to use and gives amazing results.
Exported this data to XSI via .xsi from Icarus (another good reason for using it!) and ended up with this. The cube's dimensions are 111x79x186(bricks!)
11/09/06 - Started modelling in earnest. Spent almost an hour struggling with XSI's problems with mitres. If you extrude a profile around a square path it messes up at the corners! (can't believe they haven't fixed this yet.) Found the solution with Kim Aldis's TinyThickness addon - it's great, and completed what I'd been struggling with in about 2 mins!
http://www.kim-aldis.co.uk/index.php?op ... &Itemid=59
10 hours later I ended up with this;
which isn't a bad match! I'm not planning on modelling the cars at this stage, I'm doing an office-after-everyone-has-gone-home shot!
Chucked the whole thing into Maxwell Studio via .obj [still no XSI export yet - hint, hint Juan!] and got this;
Thought something was wrong with Maxwell's sun system again until I realised that although I'd entered the correct coordinates for the location and the right date and time from the jpg info I'd modelled the whole thing with North pointing the wrong way! So I looked on 192.com for a satallite photo of the location (192.com was better res than google maps) and got this;
The red triangle shows the field of view (as best I could guess), I'm standing at the apex. So tomorrow I need to rotate the whole model and re-render...
12/09/06 - retrospectively did the diary!
1st UPDATE - Rotated the model (by 36 degrees) and ended up with this;
Clay Render ............................................................................................................ Original Reference Photo
Now it on to the texturing...!
20/09/06 - As I said I was busy last week on another project but I'm back on this one now and have added the proxy textures, just to get the scale of them right. I need to adjust the colour matching and add a gobo (stand-in silouette) for the trees.
I think I'm going to add the foliage in the shot by using photos applied on top of the shot.
Damn, I still didn't do the camera roll yet...!
10/03/06 - Well I've been on and off this personal project the last week but finally got to a point where I'm happy. Getting the colours right was hard and in the end I had to do a bit of colour correction in Photoshop (where Maxwell's material_id render proved invaluable - I could colour correct each material differently, easily) It could, of course, do with more messy textures but I wanted a clean, just built look.
C&C welcome. P.S. My building looks like it's leaning to the left but it's an optical illusion (I've overlaid the images in Photoshop and it's fine)
Final Render ............................................................................................................ Reference Photo (levels adjusted to reveal areas in shadow)
...oz out.
...oz out.
- By jack marvia
