By EONA
#183132
Tony I Get it too........ but as you say the render is fine. :shock:
Are you running the render through Rhino plugin?
By sidenimjay
#183176
there is a routine in the sdk that is called freeMaterial(); it is for cleaning out
the memory so there arent any leaks....this should/could be done after the render is complete, but it sounds like it is being done after the material is assigned or just before it is created....
its just saying that since it belongs to the scene it cannot be freed from memory......
sidenimjay wrote:there is a routine in the sdk that is called freeMaterial(); it is for cleaning out
Finally they mystery is resolved ! ...thanks for that sidenimjay ;) !
