By rob rhodes
#183049
I can't seem to get emitters to work at the moment in C4D - just getting a black cube. I used them with version 1 for a project but that was using studio. I can't seem to get them to work in either app now with 1.1. I have tried the cinemaxwell emitter tag and also the mxm tag with an emitter material and no luck. What am i doing wrong? I have been trying with a simple cube that has been made editable.
If i open a new scene in studio then i can get a preset light to work but they won't work in one of my scenes when opened in studio.
Any ideas?
By kraemerJK
#183076
You should try the usual steps first :
a) check your normals (and of course the ones of the cube.. :wink: )
b) check your scene scale
c) check your emitter intensity
Can you give us some more info on the scene ?
By Rochr
#183145
I´ve had a similar issue. What i did at the end was to delete the emitter tag, make a duplicate of the cube, delete the old one and re-tag the new cube exactly as the original. This was the only thing that worked for me.
By rob rhodes
#183583
Well guess what it works again now. Did exactly the same procedure (all of about 3 steps) and now it works! Maybe I should just try a re-boot next time!
