By dyarza
#181695
Hi everybody.
I would really like to specify aperture and obstacle maps at the command line.
Currently I am doing an animation that is going to have to do without glare, because I would have to save an mxi for each frame and then manualy apply the glare. Time prohibitive, and lets not mention how much space the mxi files would take up.
I am rendering on mxcl with a simple bat file, and since the glare would be the same for each frame, it would be as simple as:
mxcl -mxs:frame001.mxs -o:frame001.jpg -aperture:filename.jpg -obstacle:filename.jpg -t:60 -res:1280x720 etc, etc...
Having a switch to control the intensity amount would be necessary too. Something like -int:(value between 1-100)
This way the renderer would reach the desired render time or SL and then apply the glare.
Seems easy to me but maybe it's not.
Thanks,
D
By sidenimjay
#184278
please please please let us apply glare and obstacles at the command line!!!
command line is the only feasable way to add glare to an animation
pretty please with sugar on top!!!!!!
did you tried luxCore?
