By kivimaki
#175211
I posted a a WIP a while back - these are the final versions. I had to spend a ton of time working my way around rhinoll's inability to export the meshes of the furnatrue (they were .obj files imported into Rhino). I ended up exporting to .3ds and opening directly through studio...
Not the best way to work, but the only way to actually get a render out of it.
By JCAddy
#175221
These look fantastic, but that blue is a bit too much. If you desaturated those about 50% I think this image would look fairly realistic.
That fireplace metal pipe looks pretty low poly as well. Some of the furniture could use better materials. The block wall looks amazing as does the wood flooring.
How long did these render?
By kivimaki
#175248
Hyperballad wrote:These look fantastic, but that blue is a bit too much. If you desaturated those about 50% I think this image would look fairly realistic.
The one on the bottom rendered for about 4 days (it is actually 3x bigger than what is posted). I forget how long the top one rendered.
There are some problems with them, but because of the bug I was having troubles with, fixing things means starting from scratch.
very cool render.... but the fireplace is... err.... cough.... oufffa... :D
