By j_man
#175038
Hey Ernesto,
Try rendering different parts of your scene until you can work out what object it is that is causing the problem, you will probabaly be able to work out what is wrong once you know which one it is.
delete half the scene render, if it renders you know the problem is in the half you deleted so undo and repeat this process until you know where it is...
J.
By misterasset
#186017
I'm experiencing the same problem and just posted a thread about it in the Maxwell Render section? Did this ever get resolved?
By Hys
#196778
hey there,
it seems to be a little wierd bug, try to change the mxs output path.
By lpotamianos
#196976
If I get the same error, and I reset the scene and try a new one with just a box and a plane, the error will appear again. Most of the times, I will restart windows and things will be fine
