- Mon Jul 24, 2006 11:25 pm
#173366
Tag everything as they are supposed to be tagged, make the settings and press render, works fine. Congratulations, i´m impressed.
Need to do a small adjustment, stops render safely, do adjustment, press render again and i have a black hole!
Close Maxwell viewport, delete all the textures/tags, REDO everything identically, (including render settings that simply goes back to default), and it works fine again. Not so impressed anymore...
Great job with V1.1 and a very non-time saving workflow...again.
Luckily, this was a simple scene, but just how long do you think this procedure would´ve taken with 2500+ objects?
Just by curiosity, what exactly do you Beta people test anyway? The quickest way to export scenes to Studio?
Just asking, because surely this is an error that should´ve come to your attention at a very early stage. It´s fairly common practice to do a few tests before the final render.
