By goncalo
#173076
Hy I have a problem
When i had frontal mapping textures to a object
in the render appears, no texture, all in black.
If i change the texture to cubic mapping, it renders ok.
But i need to use frontal mapping...
MAXWELL DON`T ACCEPT FRONTAL MAPPING :?:
ANY CLUE :?:
Thanks
By goncalo
#173088
Here we can see with cubic projection the object on the right
Here we can see with frontal projection the object on the right
By mashium123
#173090
Hi goncalo.
Here, I've got the same problem, so I think frontal-proj is not supposed to work.
This workaround may help you, for some needs it could help indeed:
Map your tex via frontal projection. Adjust your cam, how you need it to be.
Then click on your texture tag and choose to generate an uvw-tag.
If you're done with this, the projection changes from frontal to uvw, then apply your custom-mxm and choose as "x texture tag" the newly generated uvw tag.
This way mxcl will render your scene.
Don't forget, that primitives have to be converted to polys otherwise it won't work.
You surely will have to do this all over again and again, when you change the cam perspective, because by generating an uvw-tag you "bake" the tex from the once chosen perspective.
Hope, it helps a little.
Cheers. Mesut.
By goncalo
#173091
mashium123 wrote:Hi goncalo.
Cheers. Mesut.
Thanks mashium123
arch4d send me that tip also
my 1st experience worked well
many thanks for the tips
:D
Tyrone please add this to the BUG LIST
By goncalo
#173542
THANKS TYRONE FOR THE SUPPORT
I think this is a bug... even if there isn´t and explanation was great from the moderator of CINAMAXWELL
By goncalo
#173622
Tyrone Marshall wrote:Goncalo, I will take a look at this more closely.
thanks you very much Tyrone
By lllab
#173683
thanks tyron, i had this problem too.
front mapping would be great to have.
cheers
stefan
