By Frances
#168989
Posted: Sat Jul 08, 2006 8:57 am Post subject: Memory issue for mxcl
I noticed in Task Manager that my system was using 2.09 GB of memory. Looking at processes, the numbers didn't add up to even half of that. I had 3ds Max using 196 mb and mxcl using 210 mb, actively rendering. Another instance of mxcl was a stopped render. Closing that instance freed up 1.4 GB of memory.
When a render is stopped, mxcl should release all but it's basic memory requirements.
To elaborate, I was merging mxi's in the inactive window. The loaded mxi was 113 MB. The mxcl.exe requires about 14 MB to run bare. So it doesn't account for the excess. There seems to be a memory leak - memory that TM Processes can't display, but that the Performance dialog can show.
Maxwell V1.1 3ds Max plug-in
system: dual xeon 2.8 ghz 2gb ram Win XP Pro
By giacob
#169202
maybe this can be the cause of some crashes?.... sometime i stop a render and then , whithout changing anything to the scene whatsoever, i hit render again and this time it crashes!!!... i had stopped the other render but not close mxcl...
