By redrngr
#168062
Juan,
From the formZ Forum:
By Dan Shear (redrngr) on Wednesday, July 05, 2006 - 05:41 pm: Edit
Thanks Mahar,
I noted this post though........
By Dan Kessler (dkessler) on Wednesday, July 05, 2006 - 02:59 pm: Edit
Here's what I tested...
Mac platform - Maxwell 1.1 w/ formZ 6.0 Demo = Watermark
PC platform - Maxwell 1.1 w formZ 6.0 Licensed = No watermark.
So, Am I correct that the new Maxwell to formZ plugin will run with formZ 6.0.0, when using Mac OS 10.4.X ? I do understand that Universal Binary release is forthcoming.
Dan S.
By MAHER (maher) on Wednesday, July 05, 2006 - 08:31 pm: Edit
Dan S.
I did not download the OSX version yet. my connection is really slow+am using it with XP since it is much faster, but i will try this weekend.
I assume it the new plugin should run since it works for the Pc. as for universal, it seems that it is in progress. but no dates are known yet.
-m
By MAHER (maher) on Thursday, July 06, 2006 - 06:43 am: Edit
Dan,
Yes, I get a fat watermark all over the image on OSX using V6 and 1.1
-m
By support@formZ.com (tech) on Thursday, July 06, 2006 - 09:12 am: Edit
M,
It looks like this is a confirmed problem with Maxwell on OS X. Has anyone notified Juan at NextLimit?
ZWebTech Support
Any chance you have a time frame interms of getting this bug fixed.
Thanks, Dan S.
By juan
#168101
If you are getting a water mark it is because the license.dat is not properly located in your system, it has nothing to do with osX or Windows, in fact sure that in the console tab you can read "Demo version" in that case. Below it is enclosed a list of items to check in case of license issues.
By the way universal binaries will come soon, we are putting more resources in this area to do it asap.
Regards,
Juan
HOW TO FIX MAC OS X LICENSE ISSUES
-Check that there is only one version of Maxwell in the system. If there is more than one version, it could cause conflicts in the license detection system. Also assure there is not any version of Maxwell in the trash can, it is strongly recommended empty the trash can if getting license issues.
-To run Maxwell check license.dat file is in the right location: Browse to maxwell.app location ( usually Applications/Maxwell ) and crtl+click in maxwell.app-> “show package contents”; browse to Contents/MacOS and copy license.dat in this folder.
-To register Studio license, open it and go to menu/help/license file.. and choose the location of the license.dat file
-If there is any issue after checking the previous items open a terminal (Applications/utilities/terminal ) and follow this steps:
o In the terminal window change to the directory where Maxwell is installed by typing
cd /Applications/Maxwell/maxwell.app/Contents/MacOS
o Type ./mxcl –d
If it does not work, watch the message that appears in terminal that will contain useful info to know which is the issue.
-Repair OSX permisions.
