By JuanGea
#167079
well...i was searching the problem, i identified the problem with the AGS material, if i don't have any AGS the renders start's buts i get an error:
>> Error: UVW channels ( 1 ) on object "Plane01" not enough for material "concrete-22"
any answer?
thank you all
Yes you need to assign a projector to the plane, or export it from Max with UVW map modifier and assign a material with an image map applied.
By JTB
#167269
MAX CRASHES EVERYTIME!
No matter what material I use, even with no textures, it crashes.
By Fernando Tella
#167309
Set Temp mxs path to default in Edit> maxwell preferences in studio. Also set Output mxs file to temprender.mxs in system tab in 3dsmax. That worked for me.
Edit: I've noticed that default output mxs file in max plugin is "default.mxs" and that variable has changed to temprender.mxs. The path in studio and in plugin HAS to be the same; that's the only problem (here). There is no need to set the default paths.
Last edited by Fernando Tella on Wed Jul 05, 2006 12:55 pm, edited 1 time in total.
