By smeggy
#786
I tried exporting the MXS file to my other machine for rendering hoping that I could double click it and it would render... no such luck.
Would it be possible to include *all* info needed to just render the file to the maxwell install directory on whatever machine it's sent to (maybe located by way of a 'path' argument in the environment variables) with whatever parameters were set when the file is exported. That way I could export or copy the file to my other machine on the network and when I double-click on it a render would start in the local Maxwell output directory.
At the moment the MXS file is still looking for extra info, the above suggestion would make my life very much easier.
By smeggy
#790
Thanks Animatik, worked like a charm. :D
