By 3dtrialpractice
#150269
mxcl.exe crashes when changing/assigning glare DURING rendering
(memory leak?)
when -ml is enabled Glare does not "refresh" to final render ... Only shows up in preview but never gets applied correctly to the final..
glare is inapplicable to launch with animation.. and if relaunched with maxwell viewer- with animation enable through viewer MXCL crashes
glare is not able to be launched through comand prompt.. no glare tag..
**suggestion** glare should be Numeric Field NOT slider(might fix memory leak problem too).. so that a specific number (0-100+) can be associated with glare(and can push glare intensity over 100).. this intensity numeric value come in handy if glare was able to be launched via comand prompt...
a tag like -g:95,c:\apeture.jpg,c:\obstruction.jpg
(launches glare with 95 intensity loading apeture and obstruction)
if no apeture loaded use "0"
By daimon
#150534
YES... when -ml is enabled Glare does not "refresh" to final render ... Only shows up in preview but never gets applied to the final..
I've test it and does not working for me,.
In Tone Mapping the AutoExposure also crahes every time I am trying to use it after I render something.
