#147801
please download http://www.krz9000.net/test.rar.
it contains a 3dmax .max scene with a group of edit-poly-objects and a maxwell camera.
with the latest plugin it is not possible to create a .mxs-file.
as soon as you erase the group and place a simple box object it will create the .mxs.
now the tricky part: i changed back to the beta-plugin and it creates a .mxs!
please plugin-developers take a look into this issue. there has to be a error somewhere since it clearly worked before. i tried to hunt the problem down but i can only say that i can export the group as e.g. obj and reimport and then it work. but this is not a usable solution for me since i need the modifierstack on my objects intact.(in my test scene i collapsed the mesh)
please let me know if you have the same problem or if that test-scene worked for you.
im on winxp64, amd-x2-3800, 2gig ddr400 ram, nvidia 6800gt
By Jan
#147895
You should view the info window to obtain more info about this error. It´s the known UVW error:
render frame 0 ----------------------------------
Materials info: Total Materials: 6
Bitmap info: Loaded Maps: 0 (0 missing)
Warnig: Material is not created addMaterial
Warnig: Material is not created material.forceToWriteIntoScene
Warnig: Material is not created material.getName
DefineSceneMaterials Ok
Error: Invalid U value object.setTriangleUVW
Create Geometry Ok
Error: Errors detected in scene creation phase. MXS will not be created. writeMXS
Error: MXS Write Error! (null)
See
http://maxwellrender.com/forum/viewtopic.php?t=12810
http://maxwellrender.com/forum/viewtopic.php?t=13450
http://maxwellrender.com/forum/viewtopic.php?t=11618
By KRZ
#147920
thats good to know.
seems like all those threats are moved or deleted. i try to find some info about it with the search.
thanks for the help
By Jan
#148057
I can see these threads without problems :? Anyway, if you search "setTriangleUVW" you'll find it
By Robert Cervellione
#148060
i have the same problem only i dont get an info window. it just crashes but the file worked great in rc5.
By x_site
#152549
can't see the topics either and instead of creating mxs it opens an existing one in that directory!!!!
