By Mr. Gog
#147146
When I open a model in Maxwell Studio, i get all the information perfectly.
But I can't save the File. I use save scene or save as, and nothing it's save at my HD. Any ideas or suggestion or, is a bug.
By adamwade
#148473
I had he same thing happen on the Windows version (both with DXF and OBJ formats). I need to use a my host 3D program to export an MXS file. Then open this in MWStudio, from then on it saves fine.
Just set up your objects in the host 3D program and under Maxwell rendering options hit export MXS only. Hit render, and a new MXS file wil be saved without any images being created.
This is assuming that you have a host 3D application with a Maxwell plugin....
By Mr. Gog
#148496
That's what i had been doing. Thanks anyway, It's good to know it's a real problem.
