By mtripoli
#146108
In LW, V1.0 - where do you get the "Maxwell material" setting for emitters...? When I open the material editor, I don't see where you can assign the object as an emitter...
thanks
By victor
#146179
In the Maxwell material editor, right-click in the material layers panel, and choose "Add emitter".
By ystmrk
#146453
mxm material's emitter ( in LW8.5 MacOSX ) does not work when I render a scene without MRstudio ( that means direct export to MRrender )
if the mxs open in MRstudio. emitters works.
but sky option incorrect.
ps
I don't use multilayer mesh, textures.
I use simple 2lwo ( plane, emitter ) with mxm plugin.
