By TDR
#122715
I made this scene and made a test render with no textures, and I was surprised to notice that the toilet is rendered realy wierd. As you notice, there's a big black spot on it. I tried another material and lighting setup, but still the same. The mesh has no unwelded or scrambled vertices. Here are the renders (all at sampling level 7 or 8 ):
flash light-like render, toilet uses a white maxwell diffuse shader
same set-up as above, toilet uses maxwell plastic shader
same plastic shader, physical sky & sun
wireframe
almost the same thing happened in another render:
What may be the cause of this problem and how can I fix it? Any help would be very appreciated.
Oh, forgot to mention that I use 3ds max 8 (rendered with max plugin, not from the maxwell studio) and Maxwell RC5.
Edit: also, the scale is set fine.
By samsam
#122763
Suggestion - you may have already done this but perhaps look to see if your poly normals are correctly oriented.
By TDR
#122774
The normals are all aranged fine:
http://i25.photobucket.com/albums/c87/m ... ormals.jpg
Here's another pic, from the other side. Same white maxwell diffuse shader.
In the first pics, I modeled one half and then mirrored it, attached it to the other half and welded the middle vertices. In the above pic, I used the symetry modifier on one half, but still the same result.
Edit: here's a quick render with mental ray. as you can see, everything's fine. why maxwell renders it nasty?
