By JTB
#117692
Maxwell doesn't write MXS file no matter what I do (change filename and path, change PC, run renderer after saving or not, etc).
Please help, deadline ahead!!!
By rivoli
#117713
doesn't save via studio or in max via plugin? just to ask the obvious: do your paths point to a valid position? do you have the latest plugin installed? have you tried reinstalling maxwell?
By JTB
#117745
This is not the first rendering I am doing, i have already given to the client 3-4 renderings and now, after I got back some notes and corrections, I can't continue.
By Nuno Faria
#117761
start to hide some geometry, step by step... i had the same problem because of a couch (i think it was because of lack of mapping).
By rivoli
#117769
yep, it may be a mapping problem. try to check every mat in scene to see if there is any missing one.
By JTB
#117909
Thanks, I'll try that... If it happens because of some objects then I think these objects are some 3DS trees...
