#116327
I rotate my scene inside cinema 4D after setup all scene, when i read about the sun position is now different. So to put the model in the wright position i rotate all, and after that when i make a render appears black surfaces on the triangulation objects.
New BUG Marshall
By lllab
#116347
here no problems?
stefan
By Tyrone Marshall
#116355
Hello goncalo,
Can you post some screen shots. You can use a number of free image hosting services.
Or make a simple scene with the problem and host it here for free:
http://www.mytempdir.com/
I have not encoutered this phenomenon.
Also state which operating system you are on.
By goncalo
#116466
Tyrone Marshall wrote:Hello goncalo,
Hello Tyrone Marshall
Im working on Mac os X
Here is the problem
Here is the first setup were have the North Position UP like beta
and the result on render
To make the wright position of the sun - Noth direction is left not top, I rotated all scen like we can see on the image above
and the result is this black polygons
I think is a bug ... maybe on PC no but in Mac G5 it happens.
By goncalo
#117786
Kabe wrote:Have you rotated in object or in model mode? Could be another example of the problems with object transformations...
Kabe
Hy Kabe
Yes i had selected all objects in model mode and rotated all at same time like you see on the image
