By lpotamianos
#115137
rendering from VIZ with RC5. I changed the color of a dielectric material in order to get a blue/green frozen glass effect. The render was unchanged, so I opened the file with maxwell studio and found that the material I used did not have the color changed. When I colored the glass in studio (reflectance 0) it rendered fine. Anyone else had this problem?
By JTB
#115211
Although I was one of the Studio enemmies, I must say that now, I try to do everything from inside Studio. I use the plugin only for the MXS file export.
I suggest you do the same.
By rivoli
#115220
lpotamianos wrote: When I colored the glass in studio (reflectance 0) it rendered fine.
translated mats from the plugin may not render as they should in mxcl. if they don't have textures applied it's much better to create the mats in studio and then import them in the host app as mxm.
By lpotamianos
#115506
thanks, actually I did use studio to get what I wanted, I just wondered about a plugin bug.
By giacob
#116055
lpotamianos wrote:thanks, actually I did use studio to get what I wanted, I just wondered about a plugin bug.
in my opinion also there is plug in bug: one cant have coloured dielettric with the plugin!!!
havent tried to import coloured deilettric as mxm laterial though..
