By j_man
#113828
in the meantime you could run maxwell from the command line using a batch file that is scheculed to run at a certain time...
Yes i agree, i'd like that feature aswell (in the gui).
Ditto, would be extremely useful.
Thanks,
By 3dtrialpractice
#114210
j_man wrote:in the meantime you could run maxwell from the command line using a batch file that is scheculed to run at a certain time...
HUH?
how do yopu setup a .bat file to run at a specific time?!?
this comand would be of great help if you could explain!
acctually is there anywhere i could find a refrence that explains what kind of comands like this "run at specific time" there are available to run inside a .bat in specific orders times, maybe a way to setup a bat file so it runs a comand for a specific time and then stops it, upon which running another comand?
-thanks,
luke
By breberka
#114294
absolutelly agree, but let them finish render first :)
By j_man
#114326
3dtrialpractice wrote:HUH?
It's a windows feature. look under the control panel for scheduled tasks and use the maxwell reference to make a batch file using the maxwell command line rendering. Then you can get it to start at whatever time you want.
By 3dtrialpractice
#114463
sweetness, i thought that the time would be sent off by a internal comand inthe batch, but I had never thouhgt of using scheduled tasks!
thanks for bringing this up!-thnks for the ref link-duh-:oops: - its under windows ref online
cheers!
By j_man
#114464
BTW you can use schedule task to start BB server (when installed as a service) when a computer is idle for a specified period of time. It will even start up under a different username and stop when the user comes back from luch if you get what I mean...
J.
By Cyberfish_Fred
#131047
would be very nice to have a batch renderer inside maxwell
By j_man
#131086
anyway the network rendering queue would do all this when properly implemented so hopefully soon this thread will be obselete.
J.
