By lightpixel
#112956
hy friends,
after a long time, I did some more renderings with the new maxwell engine.
here are the results.
both renderings 1500 x 1200, 13 h rendering, solution appr. 15....
- first image: one emitter plane
-second image: one emitter plane and sun.
on a dual xeon 3.2 ghz, 2gb ram, rendered directly out of 3dsmax 8.1
hope you like it.
lightpixel
very good start :)
I like it! modeling is clean, nice and very well done. Rendering looks good, a bit dimmed and monotone in it's coloring, i'm missing contrast/highlights which could be because of the surfaces themselves on the various parts of your objects.
Other than the above i think it looks great! :)
Good job!
By killian2828
#113022
in the top image the cameras look too clayish instead of rough metal, try turning down the roughness for both colors, great model!
By KRZ
#113083
hi lightpixel,
very nice model you have done!
may i ask if you like to share this "digital ixus" logo? i have no scanner at home and google-image search didnt gave me a good blueprint...therefore i have just used a close font.
here is my take on the canon-ixus50 with rc5 and skylight http://www.krz9000.net/01renders/images ... ixus02.jpg
please PM me if you like to share the logo
greets chris
By aitraaz
#113090
yep looks great! :)
By mgroeteke
#113280
lightpixel wrote:hy friends,
hope you like it.
lightpixel
nice model, but not very convincing rendering, expecially for 13h (!). the body looks more like plastic than metal. also, as a suggestion, try to make the camera 'alive' by putting a luminous image texture onto the LCD display (mabe an MXW rendering of what the camera actually sees...)
By lightpixel
#113302
hy mgroeteke,
one problem in the 3dsmax plugin, that I am not able to put some textures
in color-slot of the metal-material....so I had to use the plastic material.
is it a bug in 3dsmax-plugin??I don´t know...
yes, the display need a texture...
