By Tyrone Marshall
#112863
I am tracking all bugs related to Cinemaxwell plugin (windows and mac).
Can you give more information about how your textures are not working?
By goncalo
#113324
The same textures that i applied on materials in beta 1,2,2 that worked very nice - In RC5 plugin don´t work... at the moment i don´t have any texture working
But in MXstudio they work nice
Thanks Tyrone
By Carl007
#113340
No I to have that problem... But when I abort the render in MXCL and open up the mxs file in studio, I have the textures in the right places, and they are jpg as-well. But I try to do all my textures as .tga nowadays
By goncalo
#113342
Thanls Carl for reply
I replaced the jpg for tga
and ... the same
don´t work
By goncalo
#113343
Carl how can i open the mxs file in studio
mxs coming from C4D
when i try to open in MXstudio
i get this message
CORRUPTED MXS
This mxs is obsolete or has been corrupted
By Carl007
#113348
Goncalo, When I abort the render, I make the s"show content" command on MXCL app. in there I go to the output foilder and I get the file called "deafult.mxs" bet it depends if you have namned the render etc..
It is clearly a hack.
I copy that file to some place outside MXCL.....
Then I open it from within Studio.
Never tried to generate just a MXS file from C4D, just generate one for render, how do you do that?
By macray
#113442
To get an mxs: use the c4d-plugin and disable the "render RGB channel" and then hit render. It generates the mxs that you can load into studio without the need to abort a render.
By goncalo
#113444
But i´m not sending the renders to Maxwell
In cinamaxwell i write the file inside my project folder
Maybe this is the reason about the texture things??? could be ????
NL could say something about this, please
By goncalo
#113445
macray wrote:To get an mxs: use the c4d-plugin and disable the "render RGB channel" and then hit render. It generates the mxs that you can load into studio without the need to abort a render.
Thanks mcray
and do you have the same problem about the textures????
By Carl007
#113491
Thanks macray!
Goncalo, I don't know.....
By Tyrone Marshall
#114244
I just ran this on PC and it works. I just made sure the complete path to texture is in the cinema 4d material.
This problem could be related to OSX if textures still do not load properly.
By goncalo
#114346
Tyrone
I m working with plugin not with studio
and now the textures don't work
with beta was perfect, now i don't have 1 texture, maybe is a path problem,... i will make some tests to try to figure out this problem.
