- Sun Mar 13, 2005 5:59 pm
#9427
DELETED
as long as i know vray is the only renderer which allow you unlimited render nodes with one license (and 10 for DR if i'm not mistaken). others renderers such as brazil, mr, prman will give you a limited number of cpus per license.Maxer wrote:
Am I reading these posts right, is Next Limit planning on not allowing unlimited use of Maxwell for the purposes of network rendering?I don't know about you but the idea that Next Limit might actually charge for this when every other software provider just gives this to you is making me sick!
you surely made a point here. hope nl guys will take it into consideration as well.Maxer wrote:
Final Render also gives you unlimited network licenses and 10 DR render licenses. As for the others you mentioned it may be that they give you a limited number of licenses but look at how much they are used and by who.
