- Fri Jun 15, 2007 1:24 am
#232790
Hi, can I resume a mxi file , from a scene created from within 3dsmax?
I specify the mxi file location, and hit render. But later, when I want to resume the render, from mxcl, I pick "resume mxi", choose the proper file, and it appears a message telling :" not found. Do you want to search it manually?, click "yes" and it browses to pick a mxs file.
The problem is that, from within 3dsmax , it's not possible to specify an mxs output path, because maxwell saves a temporary mxs file (with .tmp extension), and when it finishes rendering, it deletes the file.
Any workaround?
Any workaround?
Best regards
- By Matteo Villa
