By KRZ
#167501
i just trested with a very simple scene. it has multiple objects and they all share one multimaterial. when i render from within max i get this:
> Checking Data...
>> Loading Bitmaps & Preprocessing Data...
>> Error: object buttons has triangles without material
if i assign a single-material i can render easily.
with v1.0 i could render multimat without this problem.
do you experience the same? multimat broken?
By KRZ
#167646
mmmh im clueless...the last 3 hours i tried to understand why maxwell thinks its missing a material-id.
since it renders fine with a single material it has to do with the material id. but what else can i do as selecting all polys and reassign material and reassign material id....but the result is: icant get rid of the error.
clueless...hurray NL
By giacob
#167648
dont work again
By sampson
#170085
...has anyone at all had any sucess with this multi sub?
...i can get the max ui to show the correct mapping with a 2 mxm multisub but as soon as i hit render i get the triangles problem.. :cry:
By Frances
#170088
sampson wrote:...has anyone at all had any sucess with this multi sub?
I haven't had any luck with it. I hope this and the stupid projection issue is fixed soon.
By Aji Enrico
#170139
I gave up this days ago =( even tried MAX plugin 1.0 on MW 1.1
I'm just using detach on the selected faces until 1.2
By LarsSon
#170225
For me it didn't work with Max plugin. Had same errors.
But when i opened generated mxs in studio, it was fine.
-LarsSon
By JTB
#170226
I think the solution for all MAX plugin problems -as I read from others- is to use 1.0 plugin with 1.1 engine. I don't know if this can be of any help for multi mats though.
