#401840
Hello everyone,
I have a new bug with the latest Maxwell for Rhino 8 plugin.
When I launched a Maxwell render from rhino, I can't save my rhino file directly. I have to systematically make a new recording, which is very painful.
Here is the message received.
Each time I try to save, I have a temporary file that is created in my file folder and it is not renamed and does not disappear.
it's quite painful. Any idea to correct the problem quickly?
#401867
Hello,
I'm still waiting for a solution to the problem mentioned.
I still can't run a render directly from Rhino to avoid this problem.
I guess I'm not the only user having this problem then, so it would be cool to have some positive news one of these days...
@fernando, Thank you for not forgetting me !
#401894
Hello, Thierry.
I'm sorry for taking so long to reply. If you want a swifter reaction, I'd suggest opening a support case from the portal, as I just visit the forum from time to time.
I wonder if working from a Dropbox folder could have something to do with the issue. I don't think the plugin can block the Rhino file in any way. I wonder if this happens even with a new simple scene.
Best regards,
Fernando
#401929
Dear Fernando,
I did not take the time to contact you again regarding the problem explained.
Today, I just took a screenshot which shows that it is not possible to save a Rhino file after directly launching rendering from R8.
As LockHunter shows, the 3dm file is locked by Maxwell render and not by Dropbox.
I open a support case from the portal.
Have a good day
#401930
Dear Fernando,
I read your response on the case support.
I will provide you with proof that the only one responsible for the problem is the Maxwell plug-in and not dropbox.
The file is not open elsewhere and there is only one instance of Rhino8.
The result is the same whether rendering is in progress or stopped.
I would like to point out that I have the same problem on all my PCs.
Here is a new capture : 3 software programs point to the plug in
Last edited by Thierry Debourg on Tue Oct 29, 2024 9:25 pm, edited 2 times in total.
#401931
The following window opens when I click on "Accepter"
Last edited by Thierry Debourg on Tue Oct 29, 2024 9:36 pm, edited 1 time in total.
#401932
Then I closed the rendering and tried to save again : Still the same failure.
But the 3 programs indicate that there is no use by Maxwell.
I guess Rhino 8 keeps the last information of unable to save.
#401933
To make sure Dropbox isn't responsible, I saved a test file to the desktop and started rendering there.
Fernando, as you will see in the following screenshot, the problem is still there
#401934
Fernando, I believe in you to solve this problem !
Especially since I have another one who has been ruining my life for a very long time and I'm going to tell you about it too...
#401946
Dear Maxwell users,
Fernando, from Next Limit, wrote me that they recognized the plug in bug.
They will try to release a new version as soon as possible with this and other bugs fixed that they have detected. :)
With all my support ! :D
#402002
Great news!
Update 5.2.6.8 fixed the bug I reported in this thread.
Thanks to the Next Limit team.
Fernando said :
"By the way, we have just released a new version of the plugin with several fixes and improvements: 5.2.6.8 You should be able to find it at the portal: https://portal.nextlimit.com/downloads"
#402003
Hehe,
Thank you, Thierry and everybody else, for your patience and for taking the time report the problems you find. It's a great help for us.
Kind regards.
