By piroshki
#400448
hi all - I've noticed that the settings do not seem to stick with a particular Rhino view. I was expecting that if I set the EV and output size for a given Rhino view , save my file, and return to this view - the settings will come back. Instead it defaults back to a standard EV, and the viewport resolution. This is not the way it used to work, and means you can't set anything up in advance. It would be crazy to have to reset these items for each view! Am I missing something? I am using M5.1.1.33 on R7.
By piroshki
#400449
Quick update - if you save the viewport again (in Rhino), the settings should stick. In the past one did not need to do this.
