- Wed Dec 11, 2019 4:17 pm
#399123
I'm still on v4 as the v5 plugin for Mac has yet to be released. I'm trying to work with Maxwell again on a new project to see if it makes sense for me to upgrade (I've been using RenderMan quite a bit and, for the work I do, it's pretty good).
The issue I'm running into, and have run into in the past, is that when I save an image from Maxwell Render the resulting image (whether .jpg, .psd, .png) does not look the same as the image in the Maxwell Render window. This is true when opening the image in Photoshop as well as when viewed using Preview or a browser (on Mac). This is especially apparent when applying a LUT within the Maxwell Render (I typically use Portra 160 NC).
My questions are:
1) Has this ever been addressed and, if so, what is the fix in v4?
2) If this hasn't been addressed in v4, has it been fixed in v5?
3) Does this issue effect all users or just those of us on Macs?
Thank you for your time.
Best,
Matthew
My questions are:
Best,
Matthew
- By Mark Bell
- By Mike Amos 20251018183343
