Everything related to the integration for Revit.
By Mihnea Balta
#376619
Version 3.0.5
  • workaround for Revit bug which produced misplaced faces in family instances which contained imported symbols
  • fixed: Maxwell button became unusable after opening the family editor
  • fixed: the family editor exporter wasn't using the updated exporter code in Revit 2014
  • fixed: the export button didn't work if an image output path wasn't set in Revit 2014
  • fixed: the installer didn't find the Revit install path if a localized or bundled version of Revit was used
  • fixed: the addin didn't load in some cases
By raduc
#377879
Version 3.0.7
  • fixed: exported camera framing was different from the Revit viewport
  • fixed: crash when setting the current month to January
By raduc
#379338
Version 3.0.10
  • fixed: crash when Export MXS was enabled in Pack'n'Go
  • fixed: crash in scenes that contained stills
  • fixed: railings and balusters didn't get exported correctly
  • fixed: the topology mesh material didn't get exported (2014 only)
By raduc
#379536
Version 3.0.12
  • fixed: wrong baluster positioning in some cases
  • fixed: crash when exporting some external links with Pack'n'Go
By raduc
#381002
Version 3.0.14
  • fixed crash in Revit 2015 when opening material editor with an object selected
  • fixed wrong object flags for elements with emitter only materials
  • fixed the Revit 2015 plugin was installed instead of the Revit 2014 one
By raduc
#381205
Version 3.0.15
  • fixed crash when trying to set materials in scenes with linked files
  • fixed crash when rendering scenes that contain some materials that can't be translated
By raduc
#381286
Version 3.0.16
  • fixed crash that could sometimes appear when closing Revit
  • fixed the assigned to column in the material editor wasn't accurate sometimes
By raduc
#382088
Version 3.0.18
  • added multiple selection and edit to the material editor
  • materials can now be sorted by clicking any of the columns
  • fixed plugin sometimes exported misplaced family instances
By Mihnea Balta
#382567
Version 3.0.21
  • fixed: crash when opening the material list if the MXM file names were too long
  • fixed: error "Byte_get_blue" when trying to translate some native Revit materials
By Marton Day8
#388118
Version 3.1.9
  • Compatible with the Maxwell 3.2 SDK
    Fixed: "Screen Mapped" parameter worked in inverse mode
    Added: Reflectance channel option
    Removed: BMP file format option from channel format types (bmp for channels is not supported by Maxwell)
    Changed: default channel format has been changed to exr32
    Added: opens Maxwell Fundamentals Video page before exporting to Maxwell Render
    Added: Can save render output image in PSD format (8,16 and 32 bit)
    Improved: "Maxwell Render Parameters > Render Channels > Render Type" has new options: "All, Diffuse, Reflection, Refraction, Diffuse + Reflection, Diffuse + Refraction"
    Improved: Grass can be added to Mass items too.
    Improved: Grass dialog add button width changed (to show the text better)
By Marton Day8
#389102
Version 3.2.1
Fixed: Family Symbols exported sometimes in wrong position
Fixed: Maxwell Grass panel - adding grass for an object and after that adding grass to another object was listed as the new grass were on the first object
Fixed: Maxwell Grass was not working - Now the Installer adds the right Maxwell Extension to the install package
By Marton Day8
#391249
Version 3.2.5
The new version is downloadable from the Early Build site (with lot of new/improved functionality)
Márton
