By Herve Steff
#397976
... It does render motion blur on instances.. but the shading is then off completely..
I exported from Maya.. then opened in Studio..
If I convert the instance to mesh, all is back to normal..
#398031
Hi Herve, I'm still alive.. That's a nasty bug. Well spotted.
Do you know if it only affects 4.2, never seen that before, unless the instance was flipped + a bump map in the material, but that's not happening here, unless convert to mesh could affect the normals which it shouldn't. Anyway looks like more than a bump map issue...
Could it be that the instance is not recieving any material?
