By CRAS
#295428
I made that once using accutrans 3d:
- save object (as kopy) to *.stl
- in the save dialogue choose options (bottom right)
- set the resolution of the faces (volume model will be polygonal..)
I don´t remember all the settings. You just need to try a bit.
Cheers
By Eric Lagman
#295431
Buy Moi or try the demo. http://moi3d.com/
Save as IGES or Step from SW and export out .obj with ngons. Works pretty good most of the time.
By yolk
#295449
yeah..the ngon tesselation of moi3d is awesome..just bought it
darn picasa webhosting..is there a way to upload images that stay publicly viewable?
By Eric Lagman
#295469
yolk wrote:yeah..the ngon tesselation of moi3d is awesome..just bought it
I agree. Thats the main reason I bought it. I have never modelled anything with it. I use it as a bridge between cad to other non cad apps. I wish the axis of SW models came in the same though. I always have to rotate them :?
#295473
Eric, there are a couple of ways to deal with this. First, if you are just going from SW to Studio via Moi, then open Moi's Options dialog, go to Import/Export > OBJ Options and set:
  • Scale Factor: 0.001
  • Orientation: Z-Up
That should make the SW > IGES > Moi > OBJ > Studio export path work without manual rotation or scaling. If that's too hack-ish, and you need to work with apps other than Studio, then the way to go would be, in SW:
  1. make sure you have some axis-aligned geometry; a simple cube is easiest
  2. main menu > Insert > Reference Geometry > Coordinate System...
  3. click in the X axis box, then select the cube face whose normal points in SW's x-axis direction
  4. click in the Y axis box, then select the cube face whose normal points away from SW's z-axis direction
  5. click in the Z axis box, then select the cube face whose normal points in SW's y-axis direction
You can also select vertexes and such, but it's easier to use faces. With this coordinate system now created, when you export IGES or similar and click the [Options...] button in the file dialog and look near the bottom of the File Format dialog that comes up; you should be able to select the coordinate system you created from the pull-down box. The coordinate system described above is x/y/z compatible with Maxwell.
Great, that is good news. Currently I cannot figu[…]
hardware question :)
I can easily create an usable render in 15/20 mi[…]
Let's talk about Maxwell 5.2
Price for sure matter a loot. Speed is the core i[…]
Materials translucent with V5.1
Well, the problems can be in the chair, the monito[…]
