By GABARIT
#367877
Bonjour,
I just bought the Maxwell for sketchup, I installed it, activated it successfully but when I go to the maxwell fire settings and set the resolution to the max (1920px) it stays to 800x437px.
How I can set the resolutuion to the max?
Thanks in advance
bonne journée
for infos:
windows 7 64bits,
Sketchup pro 816846
I installed before the free version of Maxwell for Sketchup.
#367880
The desired resolution is set in Scene Manager > Camera. This is then resized according to the Max Res. value set in Maxwell Fire > Settings. The purpose of this dual system is to allow rendering at a small resolution in Maxwell Fire, without actually disturbing the resolution set in the camera. So generally, you may set Max Res. to a small value while working with the scene, to minimize the CPU load and make things faster, before then setting it higher to render your final image.
