#335198
in my photoshop CS5 (32bit) when I run the maxwell Layer adj Action on a light layer i get this warning:
"command "creat clipping mask" is not currently available"
I press "continue" button and all looks and behaves well (gives me this warning in 8,16, or32bit import)
Whats this error? everything seems to work...
I DO NOT get this error in my CS5(64bit) Photoshop on the same MXI so why do i get it in the 32bit Photoshop(i prefer to work in 32bit photoshop as most of my PS plugins only work in 32 bit ps)
#335846
The clipping mask makes the intensity and color controls to be applied to a layer, so when you apply the action to a light layer, and all light layers are in linear dodge mode, you can emulate the multilight feature.
I have CS5 extended for windows and the action works well, I don't know what should be happening! Anyway, you can make the clipping mask by hand (right clic on the intensity/color control).
