#90607
There appears to be some problem with loading in objects from a .lwo file (created in modo):
Test 1:
I created a simple .lwo file using modo consisting of 4 separate named objects.
Result 1:
When importing a .lwo file all the individual objects load as a single mesh.
Test 2:
I separated the objects from test 1 into different layers prior to exporting as .lwo
Result 2:
Only the object in the first layer was imported.
Workaround: Exporting the geometry as .obj can be used resolved this issue in the short term.
-neil
By mrcharles
#93264
I have found that it is necessary to use the Lightwave plugin (updated for RC1) in Layout to create a .mxs file that is then opened in Studio.
Objects must be separated by texture if you want to preserve your material assignments made in modelling your object.
This is a problem... I cannot figure out how to import a geometry driven layer structure that still preserves model texturing...
I don't want to break my geometry this way!
the first time you assign a material to a layer you lose the imported material list...
I can't drag and drop from the material list onto the material name listed in the expanded Object list... only onto the top level of the layer.
