- Fri Nov 11, 2005 5:52 pm
#78481
i have to create a bundle to use maxwell with my application. (the plug-in is loaded at runtime).
Two problems with sdk 1.2.2a
I'm using gcc 4.0.0 and gcc 3.3, xcode 2.1 on osx 10.4.3.
1) To link with the library i must execute runlib on the libraries first; gcc gives me this error:
table of contents for archive: osx libs/gcc/libmaxwellg5.a is out of date; rerun ranlib(1) (can't load from it)
2) after that the linker gives me this error:
libmaxwellg5.a(rgb.o) has local relocation entries in non-writable section (__TEXT,__text)
the same with libmaxwellg4.a, also using gcc 3.3.
All works fine if i create an application (static executable), but with a bundle (like a dll on windows) i get the error.
Any ideas ?
tnx texsetter
Any ideas ?
tnx texsetter
- By Mark Bell
- By Edward Leibnitz
