By sidenimjay
#63797
this is nothing fancy , simply a small animation i threw together to test
material usage and motion blur with the houdini plugin
since there is not a lot goin on in the forum anim-wise , i thought i would share
all materials are represented in a an interesting 240 frame animation , playback should be 24 fps . . .
i prefer mplay for playback, that is the houdini viewer and is quite versatile with contrast and brightness etc . . .
i dont recall the render times or sample levels, but most likely it was a 5min time limit on a dual opteron 246 with 4GB ram , most likely the first cut of maxwell with SSS turned on . . .
have some other renders will post eventually . . .
can hardly wait till we have more than 2 segments to our blur . . .
http://rapidshare.de/files/5462137/mbtest.zip.html
